Non-Circular Gear Theory
Re: Non-Circular Gear Theory
hard to imagine how that rotates without shaft motion.. I dont doubt it does of course, its just hard to imagine. :)
Your good..
Your good..
Nate, the additional axes make the math easier.
I printed up a pair, the meshing is not great, though I'll blame that on the print quality for now. ... I'll probably print some more and see if I can make a working bevel gear turntable.
- ncg2.jpg (0 Bytes) Viewed 3822 times
- ncg.jpg (0 Bytes) Viewed 3819 times
Nate
For some reason they are zero bytes.. can you repost? Id like to see those...
Im not so sure Id call those non-circular bevels.. its almost as if they need their own term....
Nice work,
Nice work,
Yeah, there's a nice visual effect when using smooth curves instead of chevrons. I tend to call them 'macaroon gears' because of the way they look when the pitch angle is small.ArtF wrote: Im not so sure Id call those non-circular bevels.. its almost as if they need their own term....
I revised it with less eccentricity, lower pitch, and larger pressure angle to mitigate print quality issues, and also fixed a rounding bug. Now I have some gears that actually mesh.
Nice. I really can see why you call them Macaroon gears... :)
Nate;
These look crazy, also amazing to know they actually roll.. Nice.
You can print your own if you like, though the stl files are a bit messy.
http://www.pedantic.org/~nate/stls/twolobebevel.stl
http://www.pedantic.org/~nate/stls/threelobebevel.stl
My prints weren't perfect, but after a little wearing in they work pretty well.
Ill have to give it a shot..
