New version 1.15 of GT.
Re: New version 1.15 of GT.
Cuda Devices = 0
PS Meshing on blue and white is perfect Orange not so much but better that it was.
Cuda Devices = 0
Mine says cuda devices: 2.
It could be because I have two video cards. They aren't really powerful because they are a couple of years old, but they are there.
Steve Fox
Steve Fox
My 32 bit XP, with a wonder 9800 series shows "0"
Cheers >:(
Cheers >:(
I have a "0" for my Toshiba Qosmio Laptop
Cheers,
Mark
Cheers,
Mark
Not downloaded yet but this clunker is probably -3
Nottingham, England
Nottingham, England
Your meshing may be off because you have a wheel running on a wheel? With modified ellipticals you can only run a pinion off a wheel or a wheel off a pinion, but never a pinion off a pinion
or a wheel off a wheel..
Thx Guys:
I likely will not do too much with Cuda as yet, but its interesting how many have them. There is actually an ATI version
of GPU coding and Im only checking for NVidea's, so its likely by the look of it that most of you probably have the capability
just in case I ever decide to add any parallel processing code to GT. :)
Thx for the tests, youll see that line removed next iteration.
Ooops - sorry on the meshing third gear - senior moment!
How does one update to the newest version of software mentioned here.
On the downloads page go for the one called Current Development 4.xx
That one is always the latest.
Nottingham, England
Nottingham, England
You never need to uninstall anything, just run the new installer, all will be well.. :)
First I've had a chance to look at this.
Pressed Default and then generated the two.
what am I looking at?
Is this my computer creating an issue?
don't seem to get any complete profile with any settings for logarithmic.
Nope, bug on my part. Set Mod Coeff to zero if it isn't, and press regen before pressing tooth wheel
when you change anything , press regen before toothing.
Ill fix it up, Its still a bit sensitive..
Ya:
Found a couple problems, will issue a fix tomorrow, the toothing is much more reliable,
and the pitch will display properly. Couple more puppies hit the dust. :)
New that puppy would not run as shown, but could of sworn I'd seen a video of you generating teeth fine.
Did not want to make work for you before you left all this fine winter weather.
Stay safe, the big dog is not done yet.
Mac
Mac
Users browsing this forum: No registered users and 117 guests
