Kindest request for sample CAD file for laser cutting machine
Forum focus is on traditional conventional ways in gear cutting.
schabanow
Post by schabanow »
Hi guys!
I'm just not sure if it will be useful for my nearest future' project so I can't afford full license of commercial gear making CAD software FOR NOW. Now I just like to ask if someone of you can make for me a (free) sample - a CAD file of cogwheeled gear consists of two SQUARE cogwheels (perhaps even TWO files, not one) which quantities of teeth relate as 1/2, in order to cut them out on laser plotter? Square is about 50 mm of pinion and 100 mm of driven gear.
Thank you!
Re: Kindest request for sample CAD file for laser cutting machine
No, problem, Ill post a couple in a bit...
schabanow
Post by schabanow »
Thanks a lot Art! ))
But after almost sleepless night of mindstorming )) I came to conclusion that pair of DIFFERENT (in size) SQUARE cogwheels working in one gear, with each other - is absolutely impossible option. Only equal in size, shape and cogs' number will run properly. Two specimens of the same square wheel.
I.e. - ordinary ROUND cogwheels only, not square, can compose cogwheeled reductor or multiplicator. ((
And I will be really happy, if I'm wrong...
All in all - let me convey to you the set of local lasershop's requirements:
- the file(s) must be in .pdf (at least in .cdr);
- all objects are converted in curves;
- wireframe mode test must be applied (no excessive overlaid elements found);
- no fillings, no pourings
- all lines are hairlines (minimum thickness)
Thank you! ))
Hi :
Well, I dont do PDF's but you should be able to find a connverter. (Id check with the laser people, unusual
to see a laser that wont take DXF's....
  Alos, I dont convert lines to curves, points are more accurate, so GM stys in points..
But, heres a triangle running on a square...
EllipticalExample.zip
(94.98 KiB) Downloaded 892 times
schabanow
Post by schabanow »
Art...
Amaizing.
That was exactly I wanted. )) I think my best "thank you" will be soonest presentation of my project's rude physical expression RIGHT HERE. Based upon your kindest and absolutely free samples!
TO BE CONTINUED. ;)
ps: My KOMPAS understood .dxf just perfectly... I didn't know it to be such a smart thing... o_0
I shot an arrow into the air
It fell to earth I knew not where
mod:
I shot an arrow into the sky
It fell to earth I knew not why
That means I'm happy now just like a puppie. Thank you! See you soon!
schabanow
Post by schabanow »
Art, I don't want to be impudent, but...
Would you please to reduce the number of teeth in favour to their size? I mean that 4.5 mm of height for WOODEN (apple tree) coge is a bit smaller than I want...
Would you please to make them of 8 .. 10 mm in their height? I feel terrible sorry for I haven't specified the exact sizes from the very beginning...
You can scale them if you wish, so long as you scale both equally. But heres
a couple of larger ones..
twogears.zip
(327.96 KiB) Downloaded 1029 times
schabanow
Post by schabanow »
Well I couldn't manage to read .stl ((((
Concerning to scaling - I think it wouldn't help cause I don't need to enlarge the WHOLE wheel but its COGS (teeth) only. In order to make the model "more wooden like exterior". Like this. So I suspect that it would be completely new file, recalculated by your software. So I mean the same wheels' sizes with cogs (teeth) enlarged twice. If it's possible, of course.
Ahh, fewer teeth you mean.. Size of teeth
Here you go..
DualDXF.zip
(58.18 KiB) Downloaded 1057 times
schabanow
Post by schabanow »
And my song - from beginning to end
I've found again in a heart of a friend!
by H.W. Longfellow (by heart - by my old poor heart)))))
B I N G O !
Alex.
