Kindest request for sample CAD file for laser cutting machine
Hi guys!
I'm just not sure if it will be useful for my nearest future' project so I can't afford full license of commercial gear making CAD software FOR NOW. Now I just like to ask if someone of you can make for me a (free) sample - a CAD file of cogwheeled gear consists of two SQUARE cogwheels (perhaps even TWO files, not one) which quantities of teeth relate as 1/2, in order to cut them out on laser plotter? Square is about 50 mm of pinion and 100 mm of driven gear.
Thank you!
Thank you!
Re: Kindest request for sample CAD file for laser cutting machine
No, problem, Ill post a couple in a bit...
Thanks a lot Art! ))
But after almost sleepless night of mindstorming )) I came to conclusion that pair of DIFFERENT (in size) SQUARE cogwheels working in one gear, with each other - is absolutely impossible option. Only equal in size, shape and cogs' number will run properly. Two specimens of the same square wheel.
I.e. - ordinary ROUND cogwheels only, not square, can compose cogwheeled reductor or multiplicator. ((
And I will be really happy, if I'm wrong...
All in all - let me convey to you the set of local lasershop's requirements:
- the file(s) must be in .pdf (at least in .cdr);
- all objects are converted in curves;
- wireframe mode test must be applied (no excessive overlaid elements found);
- no fillings, no pourings
- all lines are hairlines (minimum thickness)
Thank you! ))
Thank you! ))
Hi :
Well, I dont do PDF's but you should be able to find a connverter. (Id check with the laser people, unusual
to see a laser that wont take DXF's....
Alos, I dont convert lines to curves, points are more accurate, so GM stys in points..
But, heres a triangle running on a square...
- EllipticalExample.zip
- (94.98 KiB) Downloaded 954 times
Art...
Amaizing.
That was exactly I wanted. )) I think my best "thank you" will be soonest presentation of my project's rude physical expression RIGHT HERE. Based upon your kindest and absolutely free samples!
TO BE CONTINUED. ;)
ps: My KOMPAS understood .dxf just perfectly... I didn't know it to be such a smart thing... o_0
I shot an arrow into the air
It fell to earth I knew not where
mod:
I shot an arrow into the sky
It fell to earth I knew not why
That means I'm happy now just like a puppie. Thank you! See you soon!
Amaizing.
TO BE CONTINUED. ;)
mod:
Art, I don't want to be impudent, but...
Would you please to reduce the number of teeth in favour to their size? I mean that 4.5 mm of height for WOODEN (apple tree) coge is a bit smaller than I want...
Would you please to make them of 8 .. 10 mm in their height? I feel terrible sorry for I haven't specified the exact sizes from the very beginning...
You can scale them if you wish, so long as you scale both equally. But heres
a couple of larger ones..
- twogears.zip
- (327.96 KiB) Downloaded 1108 times
Well I couldn't manage to read .stl ((((
Concerning to scaling - I think it wouldn't help cause I don't need to enlarge the WHOLE wheel but its COGS (teeth) only. In order to make the model "more wooden like exterior". Like this. So I suspect that it would be completely new file, recalculated by your software. So I mean the same wheels' sizes with cogs (teeth) enlarged twice. If it's possible, of course.
Ahh, fewer teeth you mean.. Size of teeth
Here you go..
Here you go..
- DualDXF.zip
- (58.18 KiB) Downloaded 1133 times
And my song - from beginning to end
I've found again in a heart of a friend!
by H.W. Longfellow (by heart - by my old poor heart)))))
B I N G O !
Alex.
B I N G O !
Alex.
