New version 1.15 of GT.
Re: New version 1.15 of GT.
Man, you're shop must have gotten really cold to be at −78.5 ?C (freezing temp of CO2) :)
Its the damn water cooling that'll get you.. but then...it IS Canada....
**Just SUPERB ** :)
...Non circular + spokes are really,really great !
Thanks!! :)
Thanks!! :)
So about July? After the weekend blizzard (10 foot high snowdrifts) the temp here is headed back into the negative Fahrenheits. Better weather might be skipping this year and waiting for 2015.ArtF wrote:.Once the weather improves Ill be taking the summer off for ...
Go someplace warm soon, or more than that CO2'll be freezing. After plating, although there's that whole Internet thing where you can work on the beach.
Actually, in a couple weeks Ill be laying on a Puerto Rico beach for seven days of forgetting all I know. ( that shouldn't take long..).
Then Ill consider exactly how the hell to do plating, I never liked GM's solution, too nasty to implement. Ill consider my options
for awhile before I set about doing that.
Glad you like them, every once in a while as I finish a module I think "Man, people'll like this one..", the non-circular was
such a module. I rewrote a bit of the spoking code to make them as nice as I could, and you'll find even the circular gears
spoking is a bit better under this version. The toothing speed amazed me when I figured a way to speed it up, its at least
10 times faster than GM and 10 times more accurate, I'm pretty pleased overall. GT is now starting to look like a proper
replacement for GM. Im slowly making actual headway. lol
Have fun
Have fun
What's wrong with laying out on the floor of the bar and cut the middle man out ?
I've been playing with non-circulars and am really impressed.
I can produce impossible gears with some funny drawings on the screen.
A suggestion might be to have a default button where the variables can all be put back to something that works. I can get to a point where I can't remember what the "default" value was and the gears I'm producing aren't possible, and I can do that really quickly. So a default or even a viable range for the variables would really help me.
You say on the video that the Nautilius gears are identical but on the simulation mine aren't exact and don't mesh (perhaps I'm out of the variable range)
Anyway that's my observations for now.
Thanks for the module!!
Good point. I will institute a defaults button. For now though..
Set Pressure to 20, Eccen to .5, Mod Coef to 0.
Log pitch to .2, shift to 0, stub to 1, and width to .51
All should generate with those settings...
Program updated. Defaults button is added, and a meshing bug repaired.
Also, for the ones who do download the new version, do me a favor. Check the
options tab, at the bottom it should say.. "Cuda devices : n"
What is n on your machine? This tells you if you have any GPU's I could program
which do math about 100 times faster than your CPU. Where your computer may get
8 or 10 GigaFlops, a GPU can do up to 350GigaFlops. Im playing with programming
those devices and was curious if many of you had a nvideo card capable of it.
Most NVidea's should say their available.
I'm showing 'Cuda devices: 1'
My win7,32bit laptop shows 0
Cuda Devices = 0
PS Meshing on blue and white is perfect Orange not so much but better that it was.
Cuda Devices = 0
Mine says cuda devices: 2.
It could be because I have two video cards. They aren't really powerful because they are a couple of years old, but they are there.
Steve Fox
Steve Fox
My 32 bit XP, with a wonder 9800 series shows "0"
Cheers >:(
Cheers >:(
I have a "0" for my Toshiba Qosmio Laptop
Cheers,
Mark
Cheers,
Mark
Users browsing this forum: No registered users and 134 guests
