Non-Circular Gear Theory
Nate
Post by Nate »
Are there particular references that people here like for non-circular gear theory?
I did some googling and came up with the following:
http://prozamet.pl/art_2008_3_08.pdf
http://igor.chudov.com/manuals/Non-Circular-Gears.pdf
http://www.hexagon.de/pdf/noncgear.pdf
I'm working my way through them, but I don't see anything that suggests the 'varying pressure angle' that's mentioned in the video about elliptical gears.
Re: Non-Circular Gear Theory
Hi :
Take the center document, and look at formula #11 .
  The angle between the radius vector and the tangent line is...
and then proceeds to give you a derivative formula. This tells you the
tangent is not a constant in an ellipse, thus the pressure angle will deviate
by the angle of that formula. Since in a circle the tangent is always 90 degrees
from the generation angle, the pressure angle is constant in a circle, but in an
ellipse this means the pressure angle varies as the tangental angle varies as the two
angles are always in proportion.
    Its an interesting topic, there are a lot of things to consider, so feel free to ask
when your curious as to how they work in theory and practice... I dont pretend to be
an expert, but I have spent quite a number of hours on ellipticals over the past few years. :)
Nate
Post by Nate »
... This tells you the tangent is not a constant in an ellipse, thus the pressure angle will deviate
by the angle of that formula. Since in a circle the tangent is always 90 degrees from the generation angle ...
Ah, thank you.  So you're using a different definition of pressure angle than I was.  (In my version, the pressure angle is measured from that tangent.)
Nate:
The problem with measuring it from that tangent is that it would still seem reasonable even when ( in relation to the focus) its approaching 90 degrees and can fall out of mesh. Since its importance is in meshing, the referance should be to the focal point. ( Ill give this a check in the
morning, this is from memory , but I know the formula is derived from the computation of "u" which is the angle variation from angle of generation to the current tangent. ( This is also the reason the addendum  ellipse is not the same shape as the pitch line ellipse.)
Nate
Post by Nate »
ArtF wrote: The problem with measuring it from that tangent is that it would still seem reasonable even when ( in relation to the focus) its approaching 90 degrees and can fall out of mesh. Since its importance is in meshing, the reference should be to the focal point. ( Ill give this a check in the morning, this is from memory , but I know the formula is derived from the computation of "u" which is the angle variation from angle of generation to the current tangent. ( This is also the reason the addendum  ellipse is not the same shape as the pitch line ellipse.)
I agree that that angle is important.  I'm just not sure what it's called.
According to one source::
>>According to the law of gearing, a pressure angle can
be defined as the angle between the transmission force
and speed of any point in the pitch curve. As shown in Fig.
2, the speed of point P is perpendicular to the radius vector,
and therefore, the pressure angle can be expressed as
  TRUEPA = PI/2 - u + PA;
where u is the angle between tangency and radial vector.
Nate
Post by Nate »
Is there a simple closed form for the n-lobe versions of the elliptical gears?
Hi Nate:
A Simple form..you mean of the elliptical equations?
Radius =  a( 1 - e^2))    /  (1-e* cos( order *angle)))
will work for a general elliptical formula for higher orders. Gearotics is  bit more complex
to take into account what I think is a nonlinearity of the eccentricity term of that
formula, but the one above is the one most texts use for illustration and easy to implement.
  There is no standard, so ellipticals can be made many ways and with many formulas..
Nate
Post by Nate »
ArtF wrote: ...Gearotics is  bit more complex  to take into account what I think is a nonlinearity of the eccentricity term of that
formula, but the one above is the one most texts use for illustration and easy to implement. ...
Yeah, the arc length will grow superlinearly with the order if the exentricity is greater than 0.  That's the part I was wondering about.  I guess it's just easier to do things numerically.
Nate
Post by Nate »
Yeah, the numeric profile generator seems much simpler than the analysis.  The cardioid is 1.5+cos(theta), the egg shape is generated to match it.  I haven't done pressure angle calculations yet.  Are there any other easy checks I can do before making the gears to test them?
HI Nate:
  On gears such as you have pictured, the issue often isnt the pressure angle. Its the toothing, depending on the teeth they can be hard to place
in concavities. I notice my functional generator works with  the formula theta = 1.5+cos(t) and provides the expected image only with a low number of 4 points..
(Ill investigate to see why I made such a limitation, I suspect the numbers are beiong clipped in a safety with that formula, however, even with 4
points it does show the sape you have and it reports 56 degrees max pressure angle.
Nate:
I was curious so I anaylysed why the functional doesnt generate that gear pair form that formula, Gearotic see's it
as degenerate, it runs under the radius of zero, so it limits the inflection to .2 , this makes it effectively a circular curve in the inflection
zone. But with only 4 points selected, it never see's the inflection, so you get a close approximation to the cos( theta) gear without the
inflected concavity.  The pressure angle min/max is approximate, but correct. About  56 degree's , That seems quite reasonable and if you make them
it shouldnt be an issue. (Ill have to consider if I should auto rescale such formulas to allow for the same sort of generation you show..)
  In gearotic of course, the scalar would have to be removed from the formula, the 1.5 additive term just shifts the curve to one side and the radius
is then clipped. Its that that I think perhaps I shoudl readjust my thinking on..
Nate
Post by Nate »
ArtF wrote: ...
  In gearotic of course, the scalar would have to be removed from the formula, the 1.5 additive term just shifts the curve to one side and the radius is then clipped. Its that that I think perhaps I shoudl readjust my thinking on..
Maybe I'm not following, but you can't just remove fixed radius offset like that without changing the shape.  For example, that the pressure angle due to the roll line (i.e. the 'u' in the formula above) is atan((dr/dt)/r), and adding a fixed offset to the radius will always move that closer to zero.  Similarly if you remove the 1.5+ form that cardioid, you get r=cos(theta) which is degenerate as a gear shape in multiple ways.
Nate:
Your right of course, I spoke too quicky, you should get a .5 radius min to 2.5radius max in this case... I was thinking G2 was autoscaling it.. Ill dig in the code to see wht with more than 4 points it does what it does..
Nate:
  lol, you know , Summer breaks really hurt your head. I went back and looked and it became obvious. Your formula would indeed give
that shape,but in Gearotic the formula you enter is not used for the shape of the gear, its the first derivative of the formula that defines shape.
This makes the gear ratio implied by the formula to hold true. The formula is meant to specify
the ratio of the two gears. Its why t2 = t gives a circle, it implies the two gears run at a 1:1 relationship throughout 1 period.
  I wonder if perhaps an option to enter the shape by formula with the resultant ratios ( whatever they may be ) is worth adding at some point?
Users browsing this forum: No registered users and 149 guests
