Version 2.298 online.
Ya-Nvr-No
Re: Version 2.298 online.
Post by Ya-Nvr-No »
nice job Karl, fun to see isn't it?
Art... if you didn't live so close the the NorthPole and Santa ;D
or you could dig a tunnel to your workshop.
Coldest spring I think Ive ever seen.. .. :)
KKirk
Post by KKirk »
Thanks Ya-Nvr-No
  I just can't put it down.  I stare and stare and keep thinking to myself.  It just can't be done, I know it can't be done, but there it is.  Thanks again Art for not holding back the code.  I think, just maybe Art is thinking the same thing, "it just can't be done".  It's going to church with me tomorrow.  There will be some guys there that will be very impressed!  A couple of weeks ago I gave a short talk in which I quoted Art.  And said when was the last time you did something that impressed yourself?
ArtF wrote:Coldest spring I think Ive ever seen.. ..
Here, too, until just recently.  A good part of Feburary (I know, not spring...) was -20F at night, new outdoor wood boiler was eating a full cord a week.
Although we must just be imagining it, saw recently that so far 2015 is the hottest year on record.  :o
The replacement laptop (Lenovo G50-80 with an i5-5200U) came yesterday, with 64 bit Windows 8.1 and a built in webcam (IDs as Lenovo EasyCamera).  Using that camera, and 2.2987, I tried a couple different shots, one at 320x240 YUV2. another at 640x480 YUV2, and created stl files from both with a bit under 80K vertices.  Both stl files had holes and gave very weird results (top surface all horizontal triangles) with slic3r 1.2.6.  Netfabb basic fixed them without any problem and slic3r seemed to work fine.  Netfabb's a pretty handy stl file checker and fixer and reorienter, and the basic version is free.
This is on a clean install of essentially everything, only the license file copied from another machine, fwiw.
Still haven't gotten it connected to the Printrbot, so nothing printed yet.
Hi Kirk:
  Weird, I cant think of why that error is reported, mine are clean. VCarve loaded mine to day and I cut 2 ..
They worked out the best for me yet, Ill post a video and photos soon..
Heres a few pictures...doesnt do them justice,..
https://www.youtube.com/watch?v=UgJxXuz ... e=youtu.be
  Engraving heads on my mill
ArtF wrote:Weird, I cant think of why that error is reported, mine are clean. VCarve loaded mine to day and I cut 2 ..
Slic3r's particularly picky about stl files with errors in them.
I suggest running a few files through netfabb basic; it's hard to beat for stl file checking.
I just tried a couple that I'd made on the quad core W7 desktop, with the LifeCam Cinema.  They were error free, so perhaps it's related to using the Lenovo cheap camera.  I did another one there, it had one hole.  I'll switch to that machine and attach it.
And here it is.
TestShot20150428.zip
(3.34 MiB) Downloaded 449 times
  I dont use blender as of yet, but this file passes all my ther tests, Up loads it , VCarve loads it with no errors and my at3d tests the ifule and finds it watertight. Might be some
sort of definitions errors, some programs are more sensitive than others..
Give it time, it will gradually become celar how large a problem this is..
KKirk
Post by KKirk »
Beautiful part Art.
What material did you machine it into?  And what was the resolution of the camera and the size and shape of the cutter?
I keep thinking I need a better webcam.
Karl
Karl:
  Both items are machined in sign foam, which is very fast to machine in. The camera was my microsoft lifecam.
I did do a couple tricks though...
  First, I placed black tape on each side of the camera until it framed my face. I allowed only a small
amount on either side to show, the rest was black. This made the noise field very low so it wouldnt impact the
end result , so the pull was better.
  Secondly, I allowed it to pull overnight. While 90% is done in the first few minutes, that final 10% can take awhile,
so while I slept I allowed it to continue building. In the morning I stopped it and generated the GCode. Make sure
your room is as dark as you can get it.. and uncheck the "ambient correction", while I find that can help if a small
light sourece in the room is adding noise, I find overall it detracts otherwise. Ill make it default off in future.
Keep the gradient slider to about 1.95 for the large pull.
  The results were the best sculptures Ive managed to make in all the years Ive worked in cnc. Detail is very high
as I used a .5mm cutter for the finsih pass.
KKirk
Post by KKirk »
You did not include the resolution of the camera?  I drove 60 miles today to get the finest resolution I could find.  I found a "Digital Innovations 1080P Webcam".  It lists resolutions up to 1920 x 1080. When plugged into usb port stereo photometrics only shows various resolutions up 640 x 480 with no text to the right of the resolution numbers.  Shoot I had that resolution with the built in camera.  I may take it back and get the MS lifecam.
Did you mean you put black tape on the lens of the camera?  Why not just move closer to the camera?
Karl
Karl:
  The example you see was at 800x600, but 640x480 would have worked as well I think..
The reason for the tape is the aspect ratio, your head is tall and narrow, your camera is using a wide
and short field. My camera has a window on it, so I taped over some of the left and right sides, the result
is a picture which is tall and narrow, the rest is black.. In the fall Ill be just adding a control to let you put a
mask on the video to mask off what you dont want, I wondered if it would be helpfull.. so tape showed me if it
would work.. and it does.
If the camera shows no text, its probably a format I didnt add, I used only RGB and YUY2, but some use YUYV , and
about a dozen others.. I picked the most likely two, but Ill look at adding others in the fall.
  I might add, I turned off my camera auto brightness and turned it up a bit so the image with just my monitor lighting
me up was a fair brightness. But different cameras will give differetn responce. I use low res for quick testing of lighting
conditions,it pulls out quick so you get an idea of quality, then capture at 640 x 480 or 800x600..
Users browsing this forum: No registered users and 71 guests
