Would you please review the attached file to determine why the black and orange order one gears won't mesh with the white order 4 gears.
Also, is there a way to save a gth file using the "Save As" command. There are time when I wish to modify the file and save it as a new file without overwriting the existing file.
Gary
Non-Circular gear paths
Re: Non-Circular gear paths
Hi Gary:
Hmm, the gears must have been moved, and somehow their init vectors got hosed. Ive found the issue
and corrected it, Ill see if I can get a fixed copy out within a couple days. Your project autofixes with the fix applied.
If you hit that small arrow on top left beside the save..ect.. youll find you can add a "save as" command
and a few others.
and a few others.
Thanks Art
Gary
Gary
Users browsing this forum: No registered users and 30 guests
