Hhttps://www.youtube.com/watch?v=Knb95tYQ5zo&feature=youtu.be
Here a video of the involute gear being machined.
Z axis starting point
Re: Z axis starting point
Nice to see. Re- your A axis going slow, are you in A axis radial mode? If so it should have revolved
at F20 as in 20mm/min on the circumferance..not in degrees..
The Axis is in the angular mode. I have the motoring tuning set up for 33.33333 steps per unit which is degrees for the A axis. So isn't the F20 mean 20 degrees per minute? On previous runs there wasn't the slow A axis just this latest test. Just the latest G code from GT. I made a new G code file to change the face width and make is wider. Since it wasn't a previous problem it may be a quirk on this latest test.
One other thing you are right that the teeth look a bit thin. I measured the old gear and the root width is .059 and the tooth width at it widest is .093. The new gear the root is .079 . The cutter is the .0615 so shouldn't the width of the root stay at ~.0615 with a single pass? Because it is making more than on pass is that what is thinning the teeth?
Dan Mauchg
ArtF wrote: Dan:
The option "Root Wall" will take a slice on each side of the tooth to straighten its walls.
It may be buggy, turn it off and it may be better. I suspected a bug in there with Sky's tests
but I think in the end his worked ok, but if the bug I "thought' I saw really happened, it made the root too wide by about a full tool diameter.
As to the feedrate, I put out the code with the expectation that the A axis would be used as a
circumferance object where the feedrate is the speed on the outside, so an F20 would be 20mm's per minute on the outside edge , not the actual angular speed. But thats all dependant on how Mach3 is setup. Ill make sure I look at that to option it in future.
Based on Dan's results I thought I would do some more testing with my setup and had some more questions.
I created a 25 tooth gear, DP 20.06 and Module 1.27.
The gear is listed on the Project screen as having 1.3457 Diameter
On the G-code Processing screen picture the stock width is listed at 1.3423, the height is 1.3447
On the G-code Processing menu, the material size is X 1.3776 and Y 1.3801.
I've always made the blanks the stock width or 1.3423 (at least I think I have). But since I zero at the top of the stock, I see how this can be very critical. Am I using the right number? Why not make the Z the centerline of the A Axis instead of the top of the stock. Maybe we could also have a function that trims the stock to the right diameter?
That way I get my stock close, and the mill does all the rest.
Hi guys:
I think I see the confusion. the only numbers that should be used are those in the GCode file. The file starts with a statement on the blank radius and such.
Unfortunately, I wrote the screen to display the computed extents of the stock used in the drawing..which varies a bit for display reasons. Its designed so the Gcode was to declare the blank size and such.
Ill edit that and make them match...but the file is the correct information..
I turned off the Root Wall and generated new G code. I ran another test and it was better. The old gear root averaged ~.053. The new gear measured .062 so that is pretty much the diameter of the EM. That improved the width of the involute tooth. The old measured ~.091 and the new measured .083.
So turning off the Root wall helps but is not perfect.. It was close enough that I reassembled the wiper transmission with the new gear and could not detect any noticeable backslash in the wiper mechanism. So I reassembled the whole unit into the Mercedes and it worked perfectly! It saved me a ton of money and was a fun project. I can now machine gears on a mill in addition to laser cutting them on my 100 W and 30 W lasers.
Let me know if you need any more tests while I have my 4th axis set up.
ArtF wrote: Dan:
Users browsing this forum: No registered users and 130 guests
