4TH AXIS tolerance
Brown53
4TH AXIS tolerance
Post by Brown53 »
Is there a way to limit the A axis to 3 decimal places instead of 4. My Haas will only work to .001 in the A axis. Or will I have to change this line line at a time? Would there be any problems Using the code for one tooth and then using it as a subroutine? I am new to gear cutting, so am learning on the fly :)
Re: 4TH AXIS tolerance
  The extra decimal shouldnt affect the haas, doesit trip an error?
There will be a post processor this year, but theres no way to eliminate the 4th digit currently.
Yes, you can use 1 tooth many times.. except on the non circulars of course..
Brown53
Post by Brown53 »
Ya, if I leave the 4th decimal in, it alarms out.
My regular expressions are rusty, and this is the first time I've ever used powershell (yes, I know...) so there's probably an easier way.  This assumes windows; linux would be a lot easier since you can just use sed.  Better yet, install cygwin and you'll have sed, gawk, and the other goodies.
I copied the g code file in \users\kirk so it would be easy to find.  Alternatively you could do a cd to the appropriate directory.  Start powershell; you'll get a command prompt window.
Type (or copy/paste) the following, replacing puff and puff2 with the appropriate file names.
cat puff.ngc | %{$_ -replace "(\.[0-9][0-9][0-9])([0-9])","`$1"} > puff2.ngc
It replaces all 4 decimal place numbers with the first 3 places, or at least it did in my test file.  No rounding, just cuts off the last digit.  There's probably an easy way to make it into a batch file, but I didn't dig that deep.
No warranty, no guarantee, etc.
  Thanks for that. I will see if I can quickly lower the A axis to 3 for next release, or at least offer
an option, but that may help till then..
Wod
Post by Wod »
  Just so you know, Haas doesn't mind 4 places in the X,Y,and Z. It just doesn't like 4 places in the A or B.
Wiley
Curious isnt it,, youd think any programmer would simply ignore the higher resolution...
Here's the A and B axis only version.  I should have looked into this powershell thing years ago - a now retired programmer/instructor friend (who's girls I used to babysit something like 40 years ago when we both worked at NASA) has been after me to try for years.
O'Reilly (books, not auto parts) has a book "Mastering Regular Expressions" that I almost wore out around 15 years ago.  Alas, it stayed when I changed jobs and I never replaced it - time to hit Amazon since bookpool's long gone.  Note that M$ REs are, of course, subtly different than the real thing.
Programmers are strange people; who knows why they do things :)
cat puff.ngc | %{$_ -replace "([AB][0-9\-]*\.[0-9][0-9][0-9])([0-9])","`$1"} > puff2.ngc
Fixing the case where there's more than one minus sign is left to the reader that cares.
Ken_Shea
Post by Ken_Shea »
Kirk,
Is that a setting in the Haas post that needs changed ?
Under the MultiAxis tab >Axis Decimals.
Ken
Brown53
Post by Brown53 »
I tried the powershell and I am to dumb  :'(  I tried the file name a couple of different ways. Here is what it said-
Windows PowerShell
Copyright (C) 2009 Microsoft Corporation. All rights reserved.
PS C:\Documents and Settings\greg beers> cat\Documents and Settings\greg beers\D
esktop\m24357aa.ngc | %{$_ -replace "([AB][0-9\-]*\.[0-9][0-9][0-9])([0-9])","`$
1"} > \Documents and Settings\greg beers\Desktop\m24357aa.ngc
The term 'cat\Documents' is not recognized as the name of a cmdlet, function, s
cript file, or operable program. Check the spelling of the name, or if a path w
as included, verify that the path is correct and try again.
At line:1 char:14
+ cat\Documents <<<<&nbsp; and Settings\greg beers\Desktop\m24357aa.ngc | %{$_ -repl
ace "([AB][0-9\-]*\.[0-9][0-9][0-9])([0-9])","`$1"} > \Documents and Settings\g
&nbsp; &nbsp; + CategoryInfo&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; : ObjectNotFound: (cat\Documents:String) [], Comma
&nbsp; ndNotFoundException
&nbsp; &nbsp; + FullyQualifiedErrorId : CommandNotFoundException
PS C:\Documents and Settings\greg beers> cat Documents and Settings\greg beers\D
1"} > Documents and Settings\greg beers\Desktop\m24357aa.ngc
Get-Content : A positional parameter cannot be found that accepts argument 'and
At line:1 char:4
+ cat <<<<&nbsp; Documents and Settings\greg beers\Desktop\m24357aa.ngc | %{$_ -repl
ace "([AB][0-9\-]*\.[0-9][0-9][0-9])([0-9])","`$1"} > Documents and Settings\gr
&nbsp; &nbsp; + CategoryInfo&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; : InvalidArgument: (:) [Get-Content], ParameterBin
&nbsp; dingException
&nbsp; &nbsp; + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell
&nbsp; .Commands.GetContentCommand
It looks like you're typing the full path. &nbsp;In the first one there's no space between cat and \Documents. &nbsp;The spaces in the filename n the second one are confusing it.
Copy the file to the home directory and just leave the path off. &nbsp;Stupid windoze directory names.&nbsp; You have to put them in quotes because of the embedded spaces.
Brown53
Post by Brown53 »
Did that, it saved the file with the .ngc attached. when I open that one it is blank. I might just have to bite the bullet and change a couple of thousand lines of code by hand&nbsp; :o
Thanks for the effort though :)
&nbsp; No, cant have you do all that.. Send me a note to support@gearotic.com and Ill send you a special zipped up exe that will make he A axis to 3 digits..
Brown53
Post by Brown53 »
;D ;D ;D ;D THANKS
And while you're waiting, highlight and copy the following line, get a command prompt, and type powershell.&nbsp; Do a "cd desktop" (assuming the files are still there).
Click on the screen image in the upper left corner of the command prompt window, then select edit, then paste.&nbsp; Hit enter.
I don't think you can read and write the same file this way, when I looked both of your file names were the same.&nbsp; It worked, with these exact file names, when I tried it here.
Regular expressions are pretty weird looking, and hard to retype.&nbsp; They're hard to type the first time :)
cat m24357aa.ngc | %{$_ -replace "([AB][0-9\-]*\.[0-9][0-9][0-9])([0-9])","`$1"} > m24357aa2.ngc
I didn't know you could change the desktop from a command prompt, so it was an interesting exercise.&nbsp; HTH
