I can get the Planetary feature to work in ?Tools? window but can not create a proper ring gear in the ?Project? window, shows up as a solid cylinder. Not sure if this was on your everlasting todo list or may I have a setting wrong.
Cheers,
Mark
Non-Circular Gears / Planetary
Re: Non-Circular Gears / Planetary
Mrk:
Check carefully your shaft diameter.. Only thing I can think off top of head, a few were done this week so I konw they work,
must be a setting. Take a snapshop and post it and I can probably tell you what it is. :)
I got it to work :) It appears you must enable the spokes, which makes sense.
Thanks for the quick reply Art.
Cheers,
Mark
Cheers,
Mark
