Swiss lever escapement
Palamedes
Post by Palamedes »
Any plans to add a swiss lever escapement to GM and would that translate to a larger wooden clock or are the tolerances too tight for wood?
- Pal
Palamedes
Re: Swiss lever escapement
Post by Palamedes »
- Pal
I've done one in wood (not designed in Gearotic) - the tolerances aren't prohibitive.
Im not against adding one in future..
Art;
Isn't this Swiss lever a similar but different Chrono escapment generally speaking? Appears to work in the same relative way..
It is.. but instead of a pin doing the triggering, a lever toggles between two extremes to do the triggering
of the release tooth. Its a very common watch escapement that derives from the simple chrono we have now.
Ahh.. I see it now..
Here's some pics at my attempt.
I don't run it steady because its really very loud.
