Laser or CNC?
Palamedes
Re: Laser or CNC?
Post by Palamedes »
Dumb question time...
If you output your work file (stl?) of a gear or something does it always work with all cnc machines?  that's "g-code" right?  is it a universal language or do you have to change per machine? etc..
- Pal
Re: Laser or CNC?
Only Gcode runs on most machines. An Stl file is  file format defining  a 3d object used by cam programs to generate GCode or 3d printers to print from.
