Hi,
is it possible to build a planetary gear where the sun-wheel is fixed and the planets run around the sun. That would need a rotating disc the shafts of planets are mounted to and that disc Needs to rotate around the suns shaft.
I tried alot but I was not able to build something like this in gearotic.
Any ideas?
BR
Marc
planetary gear a bit different
Re: planetary gear a bit different
Hi Marc:
You can build such a thing, but unfortunately gearotic will not simulate it, it wont allow
gears to change position during motion..
