Where do I download the newest version of Gearotic and Vexx?
Thank you...
Richard
New version
Re: New version
Hi Richard:
Downloads page of the website, use any of the 3 installers. You dont
need to uninstall , it will simply update what you have.
Re: New version
Thank you,
I have downloaded Vexx 2.0. I have been able to import a .DXF file into Vexx.
But, I don't know how you got the screen in Vexx where you installed motors to
make the wheels spin? Like in Mark's wheel in your video...
Please help.....thanks Art...
Re: New version
Hi Rocket:
In vexx you cannot use motors and springs and such. Those are parts of an experimental
package that looks like vexx, but is actually in Auggie as part of a kinetics package. To use motors
and such you need to install Auggie, and access the kinetics package by using Auggies built in
cad program. You can run the kinetics package in auggie by itself by running Auggie with the
command line -con
command line -con
Re: New version
Thanks,,,I installed Auggie 3.1, but cannot find the screen with the motors and such?
Re: New version
I found it thanks...sorry to bother you......
Richard....
Richard....
Re: New version
Richard:
If you right click Auggies shortcut and check its properties, you can change the target line
to "C:\Gearotic Motion\Auggie.exe" -CON , if you do, only the cad section will run so you dont need to
run the controller section of Auggie to get there.
Re: New version
New question: I would like to install Gearotic on my other computer. If this is permissible, how do I do that?
Richard
Richard
