Downside to that I guess is it would add a 200us delay in the laser power stream...
Ill Dwell on it... :)
Galvo Lasers
Re: Galvo Lasers
That is the way of life - "nothing is ever simple and there is always a catch".
More electronics but could you perhaps introduce an equal delay in the axis movement ?
Re: Galvo Lasers
Ill have to give it more thought. Ironically I put in a laser
delay in Auggie for servos that are slow to react, but I hadnt
considered the inverse.
Re: Galvo Lasers
First try at a single pass 3d , 1.5" round. Took less than a minute.
Not great detail, but its small on pine..
Re: Galvo Lasers
Looking good.
ElevenCubed
Re: Galvo Lasers
Do you have a link to your Arduino code used for the DAC signal conversion?
Saw your youtube video and want to give this build a try with my diy style galvo motors.
Brian
Brian
Re: Galvo Lasers
Hi Brian:
I hadnt posted it yet. It is attached to this post though. Let me know if you have
any trouble with it, I cant recall if I modified any system libraries as tweaks to make it
work faster.
I havent cleaned it up and documented it yet, so its a bit messy.. :)
work faster.
- GalvoCubeArduino.zip
- (554.02 KiB) Downloaded 981 times
Additional files for arduino
Hi :
The following zip contains a new winterrupts.c required for compiling the code in the previous post.
Also a wiring list for the arduino is included.
(Archival post)
(Archival post)
- WInterrupts.zip
- (1.93 KiB) Downloaded 1026 times
PWM post scaling device
This is a post for archival purposes. I discussed earlier in this thread the posability of using an arduino
to better control my lasers power for photos. I did make on from an arduino Due and an LCDShield 2.0,
in which a pwm is fed from Auggie ( or whatever) into the arduino, and a selected scale factor is applied
and sent out another pin.
This means at default power on operation it is set to 100% and simply passes pwm through itself,
however it can be set from 5% to 100% and will scale incoming PWM commands from 0-100% to
100 levels of selected scale power. This allows software limited to 100 slices of power, to have 100
slices of power at any set level by the time it reaches the laser.
I include a photo of the device and the .iso file for the arduino to make one. Its hard to say if
this is usefull for anything other than laser driven by auggie, Im not sure what the granularity
is of other lasesr when set to lower power. If a laser set to 20% simply allows power to be
20 levels instead of a 100 levels of 0 - 20%, this may be usefull to someone. I'll post it here just in case
someone in their searches is in need of a PWM scaler. :)
- PWMBox.zip
- (3.2 KiB) Downloaded 1031 times
