Gear placement at a given angle?
Nic Bwts
Post by Nic Bwts »
Given that the 3 gear in the picture are the same is it possible in Georotic to place the gears with a mirrored symmetry?
Re: Gear placement at a given angle?
Can you better define what you mean by mirrored symmetry? DO you mean tooth meshing on that third one?
Nic Bwts
Post by Nic Bwts »
Yeah whenever I try to put a second wheel down (the middle gear being the pinion)  I get a tooth clash
This example where the gears are at 90 deg to each other
Hmm, that seems like a bug I haven't yet seen. How is it being placed? Left gear, then top right rolled off left, then bottom rolled off of top right?
Ill run some tests..
Nic Bwts
Post by Nic Bwts »
Top right pinion then topleft rolled off top right then bottom one rolled off top right. Weirldy I cant replicate the error now!
Nic:
Cant seem to here either.. gremlin of some sort perhaps,
Ill keep my eyes open for it. Thx for the bug
Tested, works here too. Are you using the latest Gearotic version  Nic Bwts?
Nic Bwts
Post by Nic Bwts »
Yes using the latest version.
