Functional overview
Re: Functional overview
Hi YEs...  But this wont be relased for a couple days yet...
myser.SendData("xxxxxxxxxx");
  Download version of Auggie is updated to 1.43 and includes the new serial class as described..
MBad
Post by MBad »
I dont know how to Thank You ...
but now I have to go for 5 days to hospital and they do not like, that i bring my VfD with me  :-[.
Regards Michael
Take care, lots of time when you return. :)
Post by Richard Cullin »
some question re  Serial()
I have the laser licked,  time to tackle the  RS 485 VfD
Code: Select all
myser = Serial();
myser.Open(7,9600);
I assume creates a serial instance on pin 7 ?  is it an input or an output ?
[where is pin 7 on a 57cnc ?  but that's another adventure]
the only reference to outputting data I can find  is
myser.SendData("data")
so what pin would that use ?
Wow, you found serial and are dicking with that? Your not one to be trifled with.
I dont think anyone has hooked a vfd up as yet. But I did make sure the commands worked as
I put them together. Unfortunatley though, thats not a cnc57 command. Its a true serial channel open
on your PC. Thats OK if your close enough I guess and can hook a usb serial channel to your machine,
but there is  no serial hookup yet available to the pokeys board that Ive allowed a channel to. Im
afraid Im one of those people that prefrers to control my vfd by hand, so I havent put much into vfd
control..
on your PC.
[I looked for it everywhere with the logic probe  ;D]
That's  plenty  good enough ,  findings so far
sending these data sets
1,5,3,0x27,0x10,0,crc  sets spindle to 6000rpm
1,5,3,0x47,7,0,crc  sets spindle to 10000rpm
1,4,3,0,crc  will read set freq
1,4,3,1,crc  will read actual freq
1,3,1,1,crc  will turn spindle on cw
1,3,1,8,crc  will turn spindle off
just need to code  freq to  rpm calc's  and  dro updates
an a crc routine
the huanyung  vfd 485 port is not really Modbus at all ,no real time out constraints or refresh requirements at all. it looks to be quite easy
[famous last words]
Ya-Nvr-No
Post by Ya-Nvr-No »
Very cool, great to see this  :) Excellent development
Are the speeds based on your VFD spindle ranges, or are these values based on some internal data point range?
guess i'm not seeing a linearity
Also, have to assume your running the VFD direct from a usb serial port
it was based on  looking at what the mach3 vfd dll  sends to the vfd  with a logic analyser .
and I agree the data looks incorrect . I believe the correct result is 55rpm per 1Hz  of vfd freq
so :-
0x2710  = 10000  (freq x 100 )  ie 100.00 Hz  and is really 5500 rpm
0x4707  = 18183                          181.83 Hz                  10000 rpm
the vfd display verifies this
correct [elcheapo ebay rs485 stick]  I will try it with auggie today
fallen at first hurdle,can't figure out how to send a table via serial or infact anything but const ascii string
Code: Select all
// Library Vfd-Spindle
// Created  Wednesday, January 04, 2017
// Author  rc       -- Do not edit above this line
 //  Enter Global vars below this line.
//  the librarian no matter where they are, but its easier
//  to find and edit them in one spot.
//  vfd stuff
global   myser = Serial();
// called  from OnEnable
global  Vfd_Open = function()
myser.Open(6,9600);
print( "VFD opened");
//this is a relay spindle control,
//it will use only the OC output #1
//to control a relay to turn a simple
//on/off spindle, on or off.
global SpindleOn = function()
    data =table();
    data[0]=1;
    data[1]=3;
    data[2]=1;
    data[3]=1;
    data[4]=0x31;
    data[5]=0x88;
    //[font=Verdana] this fails[/font]
    //myser.SendData(data[0],data[1]);
    // [font=Verdana]this works [/font]
     myser.SendData("010301013188");
    //FreeSetSpeed( MySpindleAxis, GlobalGet("SpindleSpeed")); //turn on spindle
    print("Vfd Spindle was turned on");
    print("Set to Frequency " + GlobalGet("SpindleSpeed"));
global SpindleOff = function()
    //FreeSetSpeed( MySpindleAxis,0); //turn off spindle
    print("Spindle speed zeroed");
Ya-Nvr-No
Post by Ya-Nvr-No »
how about something like this
Code: Select all
//global  vfd={"0x01,","0x03,","0x01,","0x01,","0x31,","0x88,"}; No luck
global  vfd={0x01,0x03,0x01,0x01,0x31,0x88};
global  VFDOpen = function()
	myser.Open(6,9600); //port 6 baud 9600
       return;
 // sendData=(vfd[0]+vfd[1]+vfd[2]+vfd[3]+vfd[4]+vfd[5]);
  sendData=(vfd[0]+","+vfd[1]+","+vfd[2]+","+vfd[3]+","+vfd[4]+","+vfd[5]);
debug();
   myser.SendData(sendData);
    return;
global VFDSpindle = function(control)
  FreeSetSpeed( MySpindleAxis,control); //turn on/off spindle
  if(control ==1){
    print("Spindle On");
    SpindleOn();
  else
    print("Spindle Off");
   //SpindleOff(); // need to call/Create the Off function
VFDOpen();
VFDSpindle(1); //1 is on 0 is off
I really want to send
error is
expecting param 0 as string, got int
if I
sd=vfd[0].string()
myser.SendData(sd);
it sends  0x31  not  1
so I can't even send 1 element at a time :-[
really need to see  function template of  SendData() or something
Hi Richard:
 I think its done as follows..
global  vfd={0x01,0x03,0x01,0x01,0x31,0x88,0x00}; //terminated with zero for string conversion..
line = ToString(vfd);
myser.SendData(line);
myser.Close();
Ill dig in the code to be sure..
Richard:
While that compiles, it doesnt work as expected.. Ill trace it down and report the fix..
ToString(vfd);
that sends
table:0x13bd9fc4
looks like an address
Users browsing this forum: No registered users and 270 guests
