Version 3.0
Re: Version 3.0
kirk
  yes, the pins I think are just decorations in the stl, I had always used cages with holes and driven brass rod into the
holes, so it didnt occur to me at the time that a 3d printer would choke.. but I should be able to correct that by embedding
them into the gear same as collars..
Re: Version 3.0
Thanks Art. Had similar print results when I tried these pins earlier too, thought it was my 3D software?  Anyhow. I'll try another print if you can embed like you say, see where that goes? BTW good job guys with the projects and ideas, well done.
drezal
Re: Version 3.0 Some Cool Things
Post by drezal »
Some cool things about the latest vector wizard from Dr. Art.  I found that if somebody just wanted to play with the contours wizard you can do so outside of Gearotic.  If you open Gearotic, got to the vector wizard then close Gearotic the wizard works just fine.  Just something I noticed.
Another thing is how well and easily it exports bitmaps.  I like to work in Inkscape ((so if Art ever throws in an svg output from Gearotic I would be extremely eternally grateful)).  But for the vector wizard a bitmap export of, say a flourish, then opened up in Inkscape and then bitmap traced, gives a really cool image for a CNC cut.  I use a really cool (and free) program called jscut (www.jscut.org) for my CNC tool paths.  I've attached a couple screen shots of the flourish from Inkscape to Jscut.
http://postimg.org/image/z7ityyzl3/
http://postimg.org/image/gzgnxyb5d/
drezal
Re: Version 3.0 - This is too much fun
Post by drezal »
Or a balanced, tree-shaped flourish.
http://postimg.org/image/k9sj3wmv7/
Re: Version 3.0
drezal;
Thanks for your feedback, your right about vector wizard, it is separate to Gearotic, kind of a stripped version of Auggie to optimize speed, but nevertheless a stand alone program. It does need to be initiated inside Gearotic however, under Misc Utilities, but then becomes separate to Gearotic 3 once opened.
Vector Wizard developed in Art's head with the idea to design and decorate things such as clock faces, since our site is kind of unique to gears, clocks and things?  Anyhow the wizard appears useful in many ways in creating text, scales, vines, even to grow vines inside designated area? It is unique in what it does, will interface with Auggie for use with GCode files, and may also be used to generate raster or binary data too. Anyhow about it for now, thanks again for your feedback, have fun playing...
Bob  :)
drezal
Re: Version 3.0
Post by drezal »
Hi Bob.  Cool software indeed.  The challenge is finding more time to play with it all.
Re: Version 3.0
I hear ya, Just trying to catch up with tutorials and www.gear2motion.com
Re: Version 3.0
Hi :
  EPS and SVG output will be in an upcoming version...
Rocket
Post by Rocket »
drezal wrote: Or a balanced, tree-shaped flourish.
What numbers did you use for input to create the tree?
Kenneth P Fleming
Re: Version 3.0
Post by Kenneth P Fleming »
drezal,
Neat flourish - can't wait till I have time to play with that slick program.  You mention JSCUT - it was written by my son Todd Fleming!
Paul Fleming
drezal
Re: Version 3.0
Post by drezal »
Hi Kenneth, that is awesome.  Thank him again for me for putting out a really great program.  I have switched over to using jscut pretty much all of the time.  I've also posted many videos on using it for various CNC project.
drezal
Re: Version 3.0
Post by drezal »
ArtF wrote: Hi :
SWEET!  Looking forward to having SVG output.  Many, many thanks, Art!
drezal
Post by drezal »
Hi Rocket,
I'm not sure, actually.  I was playing around with putting in negative numbers in the motif field.  I also put in some random equations just to see what would happen.  And then I tinkered around with the circle mode option.  I'm trying to recreate it now and not having much luck.
drezal
Re: Version 3.0
Post by drezal »
BobL wrote: I hear ya, Just trying to catch up with tutorials and www.gear2motion.com
gear2motion is looking great, Bob. A quick read of a few pages and I discovered many things I didn't know about Gearotic.  I'll be checking back regularly.
Re: Version 3.0
Might just be me (Firefox 49.0.1) but the right and left edges of the page on gear2motion.com are cut off.  Or is that just a teaser for things to come?  Like those brass pins in the pictures...
