send g-code to mach 3 grayed out
Stephen Fornelius
Is this something still in development? Since I have Mach3, this would be real handy. BTW running the gear in BobCAM cuts the spokes fine, but cuts the teeth instead of the gaps between the teeth. A big with BobCAM?
Re: send g-code to mach 3 grayed out
Hi Stephen:
The "Send to Mach3" should work, but you must have Mach3 running before you start GM.
For BobCad, it sounds as if there should be a setting to tell BobCad which side to cut...I cant
imagine why it woudl cut the tooth out instead of the holes though..thats a bit weird.
Mach3 should load any Gcode produced by GM though ( Or GT..). Is there a problem there?
