when using the output manager and selecting the entire project, which would include clock hands and crank arm and using only the 2d dxf output the entire system locks up.
when selecting the gears by them selves it works fine when outputting 2d dxf files
also when I output the clock hands by them selves it will work as well
when the crank arm is selected that is when i get the lock up, I am using the 4.920 version
any ideas?
Output issue using 4.920
Re: Output issue using 4.920
Hi Rick:
Thx, Ill check that out, sounds as if the crank doesnt like 2d dxf for some reason. I likely made an assumption somewhere
about what data shoudl be inside eacj object and the crank fails the test. Ill fix it up.
