RS 11 chain sprokets
David Sohlstrom
Post by David Sohlstrom »
How hard would it be to add data for RS 11 sprockets to the sprocket data base. I have a friend that would like me to machine him some RS 11 sprockets.
Dave
Re: RS 11 chain sprokets
Dave:
DO you have any specs on them by any chance?
David Sohlstrom
Here is a link to rs11 chain data. I don't know if this will help or not.
Dave
http://www.ustsubaki.com/pdf/L10940_full_gen_cat.pdf
David:
  Ill add these to my list, Ive read this quickly and it doesnt actually have tyhe sprocket full spec, but I
can see that there are many overlaps. The British 483 type is the same sprocket as the RS160 for example..
I suspect you can already get a sprocket to match if you just try variosu ones till the outside diam and pitch diam match.
The British 483 for example is the same and off only .01" in its diamters..
ARt
