Non-circular gear problem
tweakie
Re: Non-circular gear problem
Post by tweakie »
danmauch wrote: Tweakie, cutting plywood and other woods is no problem. What you need is what is called Transfer tape.  it is called Transfer Rite
592U
www.abitape.com  I use it on ABS plastic and wood where there is a chance of flameup. The only negative is if you cut along the edge of the tape they you can get some flame up along the edge. Just make sure you are away from the edge. I got a huge roll for about $32
Hi Dan,
I have plenty of transfer tape, I use it for vinyl signmaking - Its not the wood's surface it's the glue within the ply which ignites and I am too stingy to buy nitrogen for the gas assist  ;D   Thanks for the heads-up though.
Users browsing this forum: No registered users and 142 guests
