Is there a way to include a registration pin (hole) in a gear? My situation is that I often ?stack? gears such as small pinions and if I don?t get near perfect alignment the stacked pinion is useless. If there was a pin ?hole? accurately located between the arbor hole and the tooth root, I could these two holes to accurately align the little gears.
Currently the only way I can see to do this is to export to Vectric and modify the pinion there, not the best.
Registration pin
Registration pin
Re: Registration pin
Its a good idea, unfortunately I didn't allow for it in development. I will consider adding it.
I'm deep in coding on a new package for 3d models, but after its release, Ill note to take a look
to see if I can add a tag at the zero degree point on each gear after their primary rotations.
