Hi All,
I just installed version 3. I have been using version 2 for years. I'm trying to design a gear but the program won't let me scroll down to the parameters I need to see. I can scroll down in may other apps, but not this one. Any ideas would be appreciated.
Bill
can't scroll down
Re: can't scroll down
Bill:
What resolution do you have your desktop set to? This seems as if the screen is set too small a res to
allow you to see the parameters.
Have you grabbed the top of the parameters tab and dragged it upwards to see if it
can be made to fit your screen? The project window can be dragged sideways to make it wider and the
parameters tab can be dragged higher to give it more room for the parameters to be displayed.
If you put your mouse right at the bottom of the blue screen section, the icon should change to a drag
sizer, click mouse and drag upwards to get the parameter screen to match your system. Does this help
at all?
at all?
