auggie loss of comms
Re: auggie loss of comms
I'm having a problem with the latest version of auggie posted.. i can't seem to make any movement, jogging doesn't move and also any commands entered in the mdi not working
g0 x1 nothing.. i want back to an older version 6.5 and all worked again..
The only message i get is get current com invalid. but not on every move attempt..
Gary
Gary
Gary:
Ill run some diagnostics here to see if I can see anything on the latest version.
Thanks i did check the setting's and they are the same for the old version and new, doesn't seem like any configuration's setting's have changed
Gary
Gary
Haven't herd anything were able to duplicate the issues i seem to be having with newest auggie version ?.
Gary
Gary
Hi Gary:
Sry for the delay, I think my last replay went missing.
I tested the current version by fresh install and then running several gcode programs, I couldn't find any issues.
Everything ran as expected. Are you still on the previous version?
Yes the previous version i did re download auggie a day or so ago and still had the same problem, so went back to the working version at least working for me..
tried it on 2 computers with same results.
Gary
Gary
Gary:
So it gives you no connection? Or did it connect but just gave no motion?
Are there any symptoms that might point me toward what it may be? I cant
seem to make mine fail, it just runs the same as the previous version did.
I will reinstall the newest version and get back to you maybe with a little more info.
Gary
Gary
I think the problem is in simulation mode gocde doesn't run right and jogging doesn't move the dro's hooked up the controlled and gcode and jogging working.. sorry
I always tested first in simulation mode.
Gary
Gary
Gary:
Yeah, sorry, I should explain that simulation mode is trying to run the system on a virtual; pokeys, it assumes there is none actually
hooked up, so no real signals are sent. Its more a mode for people to test the program to see what it looks like.
Users browsing this forum: No registered users and 44 guests
