(Repeat note in proper forum)
Just a bug note in Auggie. There is a flag that triggers exact stop which is being set on load
of some gcode files. This can cause the system to run only in exact stop mode. Pressing
Rewind after load fixes the problem. I will update the code on next release.
The problem can be seen to happen if you have a lookahead ( mine is set to 100 for example)
and the queue stubbornl y stays at 1. It should show the amount of queued up lines.. This of
course makes a huge differenc e in speed. Pressing rewind should fix the load and allow
proper CV operation at high speed.
Auggie Bug Sept 9 /2018
