Where are the pulley/gear tooth profile definitions stored and how do I edit ?
dfs
Post by dfs »
Where are the pulley/gear tooth profile definitions stored and how do I edit them.
The Web page alludes to this being shown in the 'Attached Video' I just don't see it.
I can't find it in the PDF manual although my search terms could be wrong.
So how do I get at them and tweak them to match my actual belt profiles.
The fact is it's probably the Chinese belts that are 'Wrong' but if I'm making the pulleys
I presume it's just as easy to buy a lifetime supply of belts so they all match each other and build the pulleys to match.
Marc Christensen
Re: Where are the pulley/gear tooth profile definitions stored and how do I edit ?
Hi Mark:
  The profiles cant be edited, they are internally defined as to the specs I have for each
pulley type. The gears are done using the involute math and have nothing stored as a profile.
  You could use Vexx to rotate a profile to make a gear if you know the various radii
and such. You can extrude it in vexx as well once created with a circular array.
dfs
Post by dfs »
So did the original program have the ability to edit the pulley tooth profiles?
I could swear I saw how to do it once...
Nope, I dont think You ever could. The profiles were always rows of numbers in an internal database. I dont think Ive ever given access to them.
