Making the Sextus clock
This is a short video showing the use of my DIY CNC router to cut out most of the parts for a Sextus clock from 7mm ply. The complete cut took about 90 minutes. The frame parts were also cut on the same machine from 12mm ply.
The plans arrived from Woodentimes as DXF drawing files and were imported into CamBam software for editting and generating the G-code for the router. The later part of the video shows the Roman numerals being cut for the modified dial. This was done using a 22 degree 'V' tool and the 'V-Carve' plug-in for CamBam.
I posted a video of the finished clock a few week ago.
This week the machine is cutting out parts for it's own next upgrade, after which it will be considerably more rigid which will make it more accurate and allow me to run it a lot faster. It will also look a lot more professional as well with a lick of paint added to make the MDF less obvious (and less pourous which is the real point).
Kit
https://vimeo.com/240094760
Kit
Re: Making the Sextus clock
Kitt:
Long cut, nice work! :)
I was glad when 90 minutes of holding the vacuum cleaner was over, but that's still far less time than cutting it all out by hand. In it's current state the framework of the macine isn't robust enough to accurately cut the depths or speeds you would normally expect for this kind of work. Once the modifications are finished I'm hoping to double both which will greatly reduce the back ache. I don't plan to install a dust extractor at the moment, I don't have much space for it and don't do enough cutting to worry about freeing up the time. But never say 'never'.
Kit
Kit
Kit:
I hear that. I cant imagine cutting most of what I do by hand..
I don't use a dust extractor either, I just periodically vacuum during the
cutting. Looks good though..
Looking good. I purchased the plans from Woodentimes for the Septimus clock a couple years ago. At the time my DIY CNC wasn't up to the task; it just wasn't precise enough. Over the last few years I've made a few different CNC machines some with more success than others. Those CNCs have been great for different kinds of projects but not good enough for meshing gears. I've have however enjoyed using Gearotic for some awesome gear projects that were not real critical.
I have an old 3040 CNC that has been modified over the years for various projects and am currently working on Clayton Boyer's Genesis Clock. Most of it is cut and a lot of it is assembled. However the 3040 is still slightly off - most likely due to a different stepper motor on the X and Y axis. I've tuned them many times in Mach but it's still a hair off; say about 1/8 to 1/16 which makes escapement wheels difficult.
Here's where the clock is currently: https://www.youtube.com/watch?v=PFHPV8CtTaM
https://www.youtube.com/watch?v=XB2qP6KS8iY
>>I've tuned them many times in Mach but it's still a hair off; say about 1/8 to 1/16 which makes escapemen t wheels difficult .
You probably have a loose coupling making it sloppy, Mach will easily adjust for
two different motors with different step counts and rates. If you run the calibration on
it , it should adjust the counts so your less than .001 off typically.
More likely mechanical though than count of motors..
Certainly could be that too. Or a springy coupler as well; they seem to have a little more play than I'd like. It's a bummer when it comes to really tight tolerances. What make CNC do you have and do you like it? After building four CNCs from scratch and playing with this little 3040 I'd like a really tight machine. One day. When I can demonstrate to my wife that it is needed. ;)
My router is from way back in the earlier mach3 days, Chinese, but with cast iron gantry and nice ball screws. Very accurate. I think they were trying to learn how to make them cheaper but were still making them heavy at the time. :)
Dan,
Nice to see the clock coming along and I always like to see other people's workshops. They always seem tidier and better organised than mine though I suspect that is what we all say.
I'm surprised you have such large errors on the CNC machine even after several re-builds. You can see that my own creation is not exactly an engineering masterpiece but it did well enough to get the Sextus working. I agree with Art that you problems are probably looseness in the mechanics, the software can be calibrated to get the steps per mm exactly correct.
Issues I've had include end-end slop in the leadscrew on the X axis (the Y axis is currently belt driven) which needs care to get rid of and flexing of the rails I'm using. The later is why I use shallow cuts (2mm or less) and slow speed (800-1200mm/min) to keep the loading on the tool down. The current upgrade is all about reinforcing the rails for both X and Y axes and making the whole gantry a lot more rigid.
Nice guitar playing too.
Kit
Kit
Kit
Kit
Hi Kit. Thanks. Each of the CNCs I've built have been sort of odd. Many of them are shown on my YouTube videos. Great job on getting the Sextus clock working! That is a really cool looking clock.
This evening I took apart a few sections of the small 3040 CNC and found a few mechanical issues. One of the bearings tends to stick ever so slightly causing a slight stutter. There is also a tiny but measurable play in the Delrin bushing for the Y axis - I have the Y set up as the "long" run on the machine.
I think we're all tougher on ourselves than we should be. When I look at other people's shops and projects they always appear so much cleaner than what I make.
Anyhow, always learning.
Users browsing this forum: No registered users and 40 guests
