I'm trying to make a gearbox and looking to change the shaft to shaft distance between gears. Is there any way to do this, or will i have to export the DXF and manually change it ??
By the this is a great program..
Peter
Changing Shaft to shaft distance
Re: Changing Shaft to shaft distance
Peter:
On the round gears creation page, there is a button labeled calculator, use that
when you have the two gears you need on the screen as wheel and pinion. The first selection
lets you set the shaft to shaft distance, the calculator will then change the mod on the gears
so they match that shaft distance..
