Version 3.02 update
Version 3.02 update
A bug has been found that slightly varies the outside diameter of some pulleys and sprockets.
The development version is now 3.02 and corrects this problem. The STL's size shoudl now match the stated spec..
Re: Version 3.02 update
Hope all is going well.
Have been unable to download the 3.02 Dev version, the stable version will download however.
Ken
Ken
Ken:
When you say unable to download, what kind of error do you get? Is this an antivirus warning?
No antivirus warning, it just showed the progress bar with no download progress(tried a number of times), one time it did and froze at 786kb as recalled.
It downloaded fine here at the house but would not at the shop, I did not try when there today.
What was weird is that the stable version progressed as you would expect.
Speaking about antivirus warning (had forgotten) a file was guaranteed when the software was installed here at the house called Optional.Amoentize
I'll try again tomorrow and let you know.
Ken
Ken
Hi Ken:
Just downloaded and installed to be sure, no errors or warnigns here. Maybe some random network thing?
Seems to be a glitch, probably OK now.
Ken
Ken
Finally got around to installing 3.02, downloaded and installed without any problems. W10 Insider's Defender didn't find any threats while installing, nor did it when explicitly scanning the Gearotic Motion directory. Guess it thinks gear porn is OK.
However the install replaced my previously edited (to say Gearotic 3.0) desktop icon with one that's titled Gearotic 2.0. Might be an installer glitch
I just downloaded this software, version says 3.012, icon is Gearotic 2.0. Should I be seeing 3.02 something?
No, thats on me, I will fix up that icon for next release.
when creating the dxf file for the Grasshopper Main Pallet there are some sections.
best regards --- Peter
Hi Peter:
Thx, I will check it out. I know this can happen in some settings, and its my list for repair..
Changing toothcount and angle can get it to go away.
