Brass Grommets For Kinetic art /sculptures
Post by Dan Mauch »
After I did my last kinetic art piece I went looking for a simple, cheap way for joining moveable links. On Amazon I found some brass grommets that would suit my needs. The brass bushings are .2505 ID and 9/32 OD (.281). I got 100 pc for $14. They are .312 long. They are ideal where you are using 1/4" material and for 1/2" material one from each side would do fine the extra length wen using two on the same pivot point acts as a bearing with no detectable friction.
You can get them from the Widgetco . www.widgetco.com item 1-250-BRS-G
Re: Brass Grommets For Kinetic art /sculptures
Thanks Dan,
Good advice. When working on kinetics one is always looking for the weird widget to
help something fit.
  I just today got my latest flipping around properly.. more work to do but this
new bat looks like it may work out. :) , Im taking a break from code for a couple weeks
to try to make another ticker for release, so its gratifying to watch it tick..
