Hello, this is my first post here.
I added some gears to my project using Autotrain and while I can select the gears with a mouse click, I can't select the shafts. I don't even see the dots that represent the shafts as in the videos. Any ideas?
Thanks.
Can't select shafts by clicking
Re: Can't select shafts by clicking
At the top of the project tree is a sort selection icon, select "sort by shafts", you shoudl be able to see and click on the shaft in that tree.
(Or am I misunderstaning the question?)
If he can't select the shaft, Gearotics may inadvertantly have the default shaft diameter on the main screen's "decorations" panel set to a small number perhaps even zero.
Bill
Bill
Hi Bill:
Good point, I recently had one report of shafts missing that was the sorting turned off on shafts, so it stuck in my mind, but its true if the
shaft is too small its hard to select on screen. They should select in the tree though, so long as they appear in the tree. :)
Sorry for the very late reply. I've spent all these days debugging the issues I had with a Nomad 883 I acquired recently.
Bill was right, the diameter of the shaft in decorations was too small (0.25 mm). I changed it to 5 mm and now I can see the shafts and select them. Thanks again for your help.
Great, glad to hear it resolved.. Have fun,
