Out of memory error when copying script to GCode
Joakim
Post by Joakim »
If a script in "MultiLine-MDI" has an unknown/undefined function and is copied to GCode tab using the  menu "MDI-Multi to GCode", "Out of memory" error pops up.
Task Manager can be used to close Auggie (or holding ESC key down).
Steps to replicate error:
1) Enter this code into MultiLine-MDI.
Code: Select all
1 { // Script with unknown function
2   unknown();
3 }
4
2) Use file menu "MDI-Multi to GCode".
3) Switch to GCode panel.
And the error dialog "Out of memory" blocks further actions.
Code in GCode panel:
Code: Select all
  unknown();
Joakim
Re: Out of memory error when copying script to GCode
Post by Joakim »
Update:
Had some problems in simulation mode with the newest version (newer than 1.48a) so I have switched back to version 1.48a.
This version correctly reports an error in the GCode panel, when using "MDI-Multi to GCode":
Code: Select all
   unknown();
Error--888,  }
No out of memory or crashing.
Thanks J:
Ill find out why..
Users browsing this forum: No registered users and 156 guests
