Using End Mill as a Drill
Any questions related to machine operation
marklazarz
Post by marklazarz »
Just finished a Brian Law clock (clock 24) and I used a 1/8" up spiral router bit to do a lot of the machining and noticed something interesting.  All of the 1/8" holes I programmed as drilling tool paths were slightly oversized, yet the larger holes I programmed as profile tool paths using the same cutter were the correct diameters.  I took the cutter and measured it and checked it for distortion and everything seemed fine.  I then put the router bit in a drill press and drilled some holes and they were all slightly oversize (say 0.001" or so).  I then put a 1/8" drill bit in the drill press and drilled a hole - perfect.  Has anyone else noticed this phenomenon?
Re: Using End Mill as a Drill
Mark;
Congratz on finishing your Brian Law clock, post a picture if you can, love to see it.  As to the oversize drill hole, could it be you have a slightly warped router bit or maybe it's the spindle itself?
marklazarz
BobL wrote: Mark;
Checked for warping, dimensions and runout.  Same results on drill press so it must have something to do with a hole being drilled with a flat bottom cutter.  I will post a photo of the clock on the "Ticker" board when I put the finishing touches on it.
Nate
Post by Nate »
Same results on drill press so it must have something to do with a hole being drilled with a flat bottom cutter.  ...
That, or chip clearance.  (Square nose bits are known to wobble when plunge cutting like that though.)
marklazarz
I think Nate is correct.  Slight wobble with no guiding point would be my best guess.
Sounds logical to me..
Users browsing this forum: No registered users and 148 guests
