G-code generated by 3-axis CNC - is this a bug?
akeller
Post by akeller »
I do not know G-code well, but my emulator reports an illegal syntax at line 10 in the generated code. The plunge rate is set to 1000.0 in the ToolBox options.
Is the 'F' character missing in front of 1000.0 in line 10? Is this a bug or is the 'F' not strictly needed?
Version used:  Gearotic 2.30080, problem easily repeatable, occurs many times in the G-code.
1  ( No Prolog Set )( GCode Objects Begin. )
2  ( Object Spur Begins )
3  G0 X0.027  Y-0.499  Z2.000  A0.000
4  (  Shaft Hole path - Inside Profile )
5  ( Tool --: EndMill2mm posted as T1 )
6  M5
7  M6 T1
8  G43H1
9  M3 S12000
10  G1 Z-3.000  1000.0
Re: G-code generated by 3-axis CNC - is this a bug?
Hi :
Ouch, yes, that looks like a bug. Are you using the default post processor?
I will investigate and repair.
akeller
Post by akeller »
Hi
I did not change the post processor, so i guess it must be the default post processor.
I am a new user and this is my first project.
Thank you, Alfred.
Thanks Alfred:
  Sounds like a bug to me, Ill get it fixed right up, surprised it hasnt happened to me yet, but various systems can see
bugs others cannot depending on settings.  Ill post a note when a fix is done..
Hi Alfred:
  New version 2.3009 fixes this error. Thx for the notification.
