Selecting Webcam
Drop zone for Webcam data
MJBoluijt
Selecting Webcam
Post by MJBoluijt »
Hi,
I try to start the stereo photometry but I can't choose a webcam, my webcam is  a logitech HD 615.
The webcam is working in normal use.
Rien.
Re: Selecting Webcam
Rien:
  No camera shows up in the selector box?
Ill take a look at the HD615 specs to see if I can see any reason it
may not show up.
Is this Win7?
MJBoluijt
Post by MJBoluijt »
Hi, thanks for fast reaction, it is the LogitechHD Webcam C615
Yes I use Win 7 64 bit, and indeed no camera in the selection box.
Hi Rien:
  DO you get a message saying
"No CaptureDevices Found on your system" , or do you get no error and just an empty box?
Rien:
  Could you also look in the log panel tab and see if there are any messages about resolutions, that may tell me something about why the device doesn't show up..
MJBoluijt
Post by MJBoluijt »
The last message is " Select an active video device"
Its odd, the log should show either the number of devices found or an error that none were..
Ill dig into it to see if I ca at least add more messages toi help track it down..
MJBoluijt
Post by MJBoluijt »
Perhaps the following info is useable for you.
I can use the Camera in Picassa also in Mach 3 Klaus video screen  and in Mach 3 Tormach CNC Scan.
Regards,  Rien.
Rien:
Can you check the log again, are you sure there are non messages in it to resolution, the code
is written to have no choice, it will always tel me what it saw. The log tab is a tab on the properties window that never goes away. Check it for me,
I shoudl at a minimum say something like..
No CaptureDevices Found on your system."
in the log. Can you tell me the sequence in there..Is truly nothing seen?
MJBoluijt
Post by MJBoluijt »
This is all I see in the log file;
Engine in Idle state
Item locked in place
select tool on Left or load project to begin
Initializing complete
Select and activate Video Device
Rien.
Rien:
  Ill put out a new version today with more messages to help me track down why your camera is being rejected,
then Ill see if I can do something about it..
MJBoluijt
Post by MJBoluijt »
This is what I see in the log file now with the newest version;
Creating Capture Device
Finding Capture Devices monikers
By the way there is no reasen for hurry.
Rien.
Thx Rien:
  Odd, Ill see what stopped it form progressing from there.
Users browsing this forum: No registered users and 145 guests
