I'm using version 2.30030 and have removed random teeth off of the pinion in the Cage Gear Rhythmic Geneva type, if you do an even number of teeth on the Wheel and even or odd on the pinion, the graphical representation is off, the pins on the wheel are into the pinion.
If you do an odd tooth count on the wheel it works fine.
Cage Gear Rhythmic Geneva Type
Re: Cage Gear Rhythmic Geneva Type
Thx for the report, I will look into why. :)
OColumbus;
Thanks for the report, I agree something funny there.
