 Minor update.
-- 4th axis tangental will pull out to zero between flanks to try to stop cutoff on cut flank from slitsaws.
-- Shaft holes may be rotated on a gear if not circular. Just select gear and use the angle+,- on properties tab.
-- Changes to the Wed3d for stability.
						Re: Version 2.300 online
  This version has just been updated to fix a bug, please redownload if you updated to this version. Your old projects will not load
with that bug, and any projects you create will not load once fixed. Sorry for the error.
