Confidence - suggestions, please
Drop zone for Webcam data
DanL
Re: Confidence - suggestions, please
Post by DanL »
if you have background lighting that can make the images not come out very well with a very low confidence, your one is the next up from mine I get between 50 to 80 confidence depending on the color of the background white was low, black was in the middle, mdf was at the high end.
I have mine in a box with a screen behind the camera on arts new version it was far to good having a set up in a box, the pictures were coming out picture perfect with a depth of 3 m
BMeyers;
I'm not sure how you improve the confidence from 4 to 80's other than darken the room and brighten the monitor flash. We used a white background in our test with a 25in monitor, if I remember correctly we got in the 60-80 first try. Is the brightness turn all the way up on your monitor?
BMeyers
Post by BMeyers »
Bob,
You mention "monitor flash".  If that means a flash from the web-cam, I do not notice any flash from the web-cam during "fire".  That would also explain what I observed in the jpgs attached to another string under this topic (the light on the object appeared to be coming from a different direction between the shots).  I don't see mention of "flash" in my web-cam user manual; and do not know how to get it to do that even if it is capable.  If the camera is supposed to flash, that would explain why the 4 photos don't yield the information needed to make a good rendition.
If "monitor flash" refers to another device, please explain.
Regards,
Brian.
Brian;
The monitor is your flash, the closer you are to it the higher your confidence number will be. No web camera flash is necessary.
BMeyers
Post by BMeyers »
Ah.  So it is the alternating black/white image on the monitor, if facing the object, provides the slightly differently angled lighting which enables the program to approximate depth.  Hmmm. the monitor was certainly facing me when I previously attempted some portraits - with low confidence results.  I will try the process at night (otherwise the sun will make the room bright) to allow the monitor to provide the light, once I replace the web-cam I returned earlier today.
Thanks.
DanL
Post by DanL »
Brian your webcam will be more than good enough it`s better than my one, you just need a dark background as in no light or just a little bit. stick a blanket over yourself and the screen, that will do the trick go old school
BMeyers;
That's right, a dark room, capture image as close to your monitor as possible when taking the shot and if you can have a white or black background that really makes things better.
BMeyers
Post by BMeyers »
DanL and Bob,
Thanks for the pointers.  Might be awhile, but I will give it a go.
Regards,
Brian.
Yes, results really require a dark room and a monitor bright enough to make a difference. Turn your monitor brightness up full
for the shots if you can.. it can really help. Many never notice how dark their monitor is after a few years, I just replaced both my primary
monitors this year and they near blinded me ..my old ones were much worse than I thought. I use a widescreen, so I dont need to adjust anything, the photos work out great usually.
Users browsing this forum: No registered users and 34 guests
