Chrono Material thickness
When designing a clock using the Chrono - I can set the gear thickness for the gears but not for the Chrono mechanism - am I missing the thickness set up on the chorine - where is it?
Re: Chrono Material thickness
  They are set to 50% the thickness of the ratchet. It seemed reasonable at the time. My thinking is it was more a display issue as the GCode output is easily modified for any thickness.. however, STLs and other solids have become increasingly important, so I will add a method to
reset those to user selectable thicknesses..
