STL Import into Cura are ten times larger than intended
A discussion and development of a 3d printer is located here.
Rickam
Post by Rickam »
Gearotic STL output module works very well.
But I did notice that the scale of the project imports into Cura at ten times larger than actual size.  It's not a big problem shifting one decimal to re-scale, but I was just checking in to see if anyone else had the same experience. - all best!
Re: STL Import into Cura are ten times larger than intended
Rick:
Havent had that issue, the coordinates int he STL's are all absolute from the model, so it sounds like
cura may be applying a scale factor for some reason.. perhaps its set to centimeter mode?
John S
Post by John S »
Only the BBC and dressmakers use centimetres.
Wonder what the BBC measures in Centimeters.. :)
