New Questions
Hwingo
New Questions
Post by Hwingo »
Art:
1. Does Gearotics default to 20 deg PA?
2. When I close out Gearotics and then re-open the program, previous working data populates all the fields. Is there a way to make the program open without having the previously used data populating the various fields?
Harold
Re: New Questions
Hi Harold:
Yes, 20PA is a standard most gears follow, so it comes up as the default, many of the entries do
have a memory though so that your last usage is repeated.
  You CAN reset everything if you wish, yo ujust need to run Gearotic, whlie its running, open the task manager and kill the Gearotic Process.
When you restart Gearotic , it will ask you if youd like to reset all values, if you say yes, all the original values will be set.
Hwingo
Re: New Questions
Post by Hwingo »
Thanks Art. Much appreciated.
Harold
