Ver 2.281 Nothing in the tool screen
Dan1931
Post by Dan1931 »
H Art, I just downloaded ver 2.281.
When I select tools and try to create a gear or any thing else I get a blank work space with some words in the upper RH corner, A target in the center of the screen and the words "Pick Object".
Below the line ( properties) I get the standard work space.
Can't get any thing in the work space.
When I click to add a wheel or pinion the words (Project tree) comes up but no Part.
Help please
Re: Ver 2.281 Nothing in the tool screen
  Really? With anything?
Id try a reset, sound sliek your numbers may be messed up.. Run the program and open task manager, kill the Gearotic process and then run Gearotic again. Select "yesy" when asked if youd liek to reset everything. Does it then make the object?
Dan1931
Post by Dan1931 »
Hi Art, Thanks it worked.
