Hi All, I have an encountered improper argument which I can't get rid of. I downloaded the development version and installed it and still have the same fault. I loaded onto my workshop PC and all is OK so I must have done something wrong on my laptop installation. I tried using task manager to cancel Gearotic but when I restarted it I got no option to reset to defaults. I held my puppy close when reporting this problem and he survived!
Many thanks
Les
Re: encountered improper argument
Les:
Very strange. If you use the task manager to kill it , it should ask next startup if youd like to reset. Im thinking perhaps its failing before the reset option is seen.
Are you familiar with Regedit? You can delete the key named "Gearotic Thoughts" to do a manual
reset...
reset...
LesMarx
Hi Art, When you're good, you're good......that nailed it! Thanks a million for the fix and the most amazing program.
Les
Les
