How do I determine the drive gear?
How do I change the drive gear?
Change drive gear
Re: Change drive gear
The drive gear is the frst gear you place. To change it you can select any gear in the project tree,
right click it, and select "Set as Master". You would then have to redo all the linkages to make the simulation work properly...
