Big Bug
Ren? Olivier
Big Bug
Post by Ren? Olivier »
Hello To everyone
I have done a design for a clock and all was good, good rotation and good timing
I save my project and close the gearotic program. When I reload my project several gear are not turning. After several test, I discover when you rename the gear and save your project again,and you close the program to launch it again, the gears are not turning or the rotation have changed on some
Somebody know why
Re: Big Bug
  Thanks, that does sound like a but and Ill check it out.
You can fix it.. Youll probably find the linakges are broken, watch the GUI video on linkages and how to make them, just
select a gear that should drive another but doesnt, and create a link so it does...
