it seems that both the wheel and pinion teeth number up down tabs now only increase the tooth count , once the tens digit has changed
"circular gears" selected
circular gear tooth count
Re: circular gear tooth count
Hi Richard:
I cannot repeat that one here, the tabs seem to increase and decrease OK here. Anyone else seen
this problem?
this problem?
Richard;
Can't duplicate that here either using Ver 2.00.. However does appear slower than usual for what ever reason..
after restarting pc I can't reproduce the fault either , I'll call it an undocumented windows feature
Always best.... :)
