bore dia.
MK
bore dia.
Post by MK »
I am new, my question is can you, when developing a gear train have differant bore sizes
on the pinion and master gear. I am using Geartronic V 4.67.
Re: bore dia.
MK;
Yes you can, however I'd suggest you use Gearotic Thoughts to generate them. To do that, please go back to www.gearotic.com and to the download page, then download Dev Ver 4.XX to your computer and install since you do not have this version using version 4.67.  This will install Gearotic Motion and Gearotic Thoughts on your computer, and from your desktop, double click icons Gearotic Thoughts to begin.
In the circular gear tab, when creating your wheel, set a shaft (bore) diameter to your requirements and once complete "add wheel to project". Next go back to your circular gear tab and create your pinion, select a new shaft (bore) size for your pinion gear and then select "add pinion to project". Should work...
Hope this helps..
Re: bore dia.
You can also change the shaft sizes after the fact on any gear, just select the gear while its on the project screen, change the shaft diam setting at top of screen and press "Respoke" button, the shaft hole will change..
