I'm going to use ball bearings on my clock arbors. I got .125 ID x .375 OD x .155 thickness bearings from a supplier. When I plug those numbers into the bearing props the ID wants to stay at .250 no matter what I put in. Using latest download, 5/17.
Steve
ball bearing problem
Re: ball bearing problem
Hi Steve:
Hmm. Here's a snapshot of what I get, what does yours look like. At .250 there cant be much displayed is there.?
Steve:
Sorry, I see now what your saying. The dia:.250 on the screen is wrong. The bearing on the screen is correct, the text is wrong, Ill fix that up..
Text for the bearing ID is repaired for next version. Just change shaft dia in meantime for proper display.
